The distributor mounting flange (aluminum) has most likey frozen to the intake manifold (iron or alum). Careful heat from a propane torch should break the bond. Be careful not to overheat the distributor housing.
Had that problem before and if you`ll use carb cleaner instead and work the dist back and forth while spraying it then it will come out and not have to destroy the dist... The propane torch is a last resort because it will ruin the seal in the dist... Remember heat travels quickly in alum...
brake kleen would be the best thing to use. Also turn the engine over. Could very well be that the dis gear is stuck to the cam.
