I have a '69 Camaro, automatic trans, with a tilt steering column, with the gear selector on the floor. My problem that just occurred is that the key all of the sudden is stuck in the ignition and I can't get it out. Can anyone tell me what may have happened and how do I go about repairing this problem.
Thanks.
First of all, is the ignition all the way in the lock position? If so, 2 possible issues:
1, steering wheel lock,
2, shifter lock.
I would try wiggling the steering wheel first, see if that does it, if not, maybe try the shifter. If that doesn't help either, take a look along where the steering column where it goes through the firewall, you should see linkage for the shifter lock. Try wiggling the lock here, as it may be bound up.
Chris
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
