stuck in low gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2005, 02:24 PM
New Member
stuck in low gear
this is not really a hot rod question but thought somebody might be able to help me out. My 2004 Trailblazer seems to sometimes shift itself to a lower gear when starting out from a stop (at least thats what it sounds like - low power and engine strain). When you continue to run it is eventually changes up, but sometimes takes a while. It also seems to do it after driving for sometime. ANy help would be appreciated.
thanks
Old 12-28-2005, 06:38 PM
i believe not as a fact that your problem is that the torque converter is locking in overdrive when you start off since the computer is sensing a signal from a defective throttle position sensor telling it that you are at the speed and rpm range that it the converter is suppose to lockup at to give you better mileage and reduce the rpms i had a camaro that would lockup and would not unlock unless manually downshifting and i purchased a new sensor and adjusted it to the right voltage and it worked perfectly from then on.
Old 12-29-2005, 09:55 AM
sbchevfreak's Avatar
Licenced Automotive Technician
If your lockup clutch was stuck on, then tou would stall when coming to a stop. On an 04, take it in and have the trans data monitored while the problem is occuring, the scan tool will be able to see what is happening with the TCC, and all other trans data.
Old 12-29-2005, 02:49 PM
tnsmith10's Avatar
when will it rain???
thanks
from what i am reading, if i understand u correctly, the car is hard to get moving but once up to speed seems fine, right? if that be the case, then, 1 question would be have u had the trans serviced lately? reason i ask is because it seems to be starting out in 3rd gear... and those, like the s-10 series have tight clearances for trans pan removal, its not uncommon for a shift solenoid to be broken trying to get the pan off or back on.
on the other hand, how many miles does it have on it? old age on the trans? could be part failure, is the a service engine soon light on? in any case, it sounds like u need to go to a transmission shop and have it checked. they can do a full diagnostic and computer scan and tell u exactly what is going on. gl
Old 01-17-2006, 09:48 AM
New Member
just was able to get back to this issue. what i have noticed now is that it seems to be the engine itself. even in park it seems to strain some times. in that i mean it sounds like you are driving it in a low gear. sorry to mislead to the trans ato begin with.
Erson Gear Drive Woes blndweasel Engine 9 07-14-2004 09:53 AM
Gear Swap. M&M CUSTOM Transmission - Rearend 3 06-26-2004 05:53 AM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 04:50 AM
3.70 rear end gear change lori-due Transmission - Rearend 3 12-28-2002 08:25 PM
Speedometer Gear Change ? bigjoedo Transmission - Rearend 3 07-04-2002 06:52 PM
