Stuck Muffler - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2008, 03:51 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
Stuck Muffler
I want to experiment with my car and see waht it sounds like minus the muffler.
I loosened the front clamp and one bolt on the back clamp is rung off.
so both clamps were loose but the muffler wouldnt budge i sprayed both ends with liquid wrench. any tips on trying to get them loose?
Old 04-29-2008, 03:59 PM
Block of two by four and a good big hammer. Be ready to have difficulty reinstalling it. Use new muffler clamps and use plenty of anti-seize on the u bolt threads.
Old 04-29-2008, 04:09 PM
cope's Avatar
i have had good luck using lots if wd-40 and twisting it other times i have had to cut the pipe right in front of my muffler than cut some slits down the pipe and bending it in and beating it back and forth with a hammer
Old 04-30-2008, 08:25 AM
SS66chevelle's Avatar
HR VIOLATION
Eastwood sells a tool to remove the mufflers without damaging the pipe/muffler. I had a similar issue...
price depends on the size of your pipe
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Old 04-30-2008, 12:23 PM
Loud you are wasting your time doing what youre doing youre just going to make trouble for when you go to put it back on not only fitting it but possible exaust leaks you might have afterwards.
If you have a welder you might be able to luck out
Old 04-30-2008, 07:52 PM
Just unhook it at the exhaust manifold, gaskets are only a couple bucks a piece.
Heres my truck with open headers,look at my other video for a soundclip of my homemade mufflers http://www.youtube.com/watch?v=jjT-CnMCY0U
Shane
Dual inlet/single outlet Flowmaster SUV 50 Series Muffler for AMC 304 Houman SS '70 Engine 2 12-18-2007 08:14 AM
Catalatic After Muffler? COUGARPOWER Engine 13 01-26-2007 10:06 AM
Kind of ON-topic: muffler decarbonization jojo99 Engine 7 06-28-2006 11:13 PM
muffler help cruiser22 Engine 1 01-31-2006 09:51 AM
Building a muffler TurboS10 Hotrodders' Lounge 15 03-24-2004 04:09 PM
