stuck muncie - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2013, 03:53 PM
stuck muncie
I have a '65 stingray with i believe a m-20. out of the blue it has gotten stuck in gear, i checked the linkage and all appears to be fine . not sloppy at all and clean. I can shift thruogh all four geard but it is in reverse too at same time. if i put it in neutral and start it up with clutch in and let it out it is in reverse. regardless of which gear i put it in, it will be in both. what do i need to do?
Somebody help a frustrated new vette owner !
thanks
Old 10-23-2013, 04:58 PM
BOBCRMAN@aol.com's Avatar
Either the shifter arm or rod has fallen off the tailshaft of the trans or the reverse shift shaft or slider has come out.
Old 10-23-2013, 05:39 PM
all i know is it was driving fine with no issues and at a stop sign put it in neutral, and when I went to put it in gear it would only go in 3rd gear and was stuck in 3rd all the way home. (couple miles) parked it and when I was able to get under it inspected arms, spacers ext. wiggled everything and lined up the arms to what I thought was neutral and noticed that i was able to run shifter through 1-4. set it down (just had it up on 1 side so never really knew if it was in neutral) and now it is in reverse !
thanks
byrneone
Old 10-23-2013, 06:54 PM
jokerZ71's Avatar
Wrench Turner
When they get some wear,they get bad about hangin between 2 gears.If that's the case here'sometimes you can rock the car back & forth while working with shifter & get it unstuck.It's also possible that you weren't in neutral when you set the linkage.Try go thru the proper linkage setup making sure no linkage rods are bent..Other than that as stated earlier,something has came loose inside.IDK if it really helped,but,it seem to,but,we used to put a can of STP oil treatment in them when they got bad about hanging up.If you have the short throw shifter,it's even worse about hanging up.
Old 10-24-2013, 12:17 PM
I bet the ball and spring that holds the reverse link has dropped out; or the whole trans is just whipped to death. No amount of miracle in a can is going to fix it. The reverse link is in the tailhousing; so you have to pull the trans to service it. Id advise pulling it regardless and see if you can get it to shift on a bench.
You may get lucky and something is bound up, but Id say you're in for a rebuild. When you pull the trans, look at the front of the case, below the "snout" the throwout bearing rides on is a hole about 7/8th or 1" in diameter. Thats the countershaft hole. If its leaking oil from there, or someone stuffed silicone or loctite in it...the case is shot, and likely you're looking at starting over. Buy a book, take it apart and then build it right. Use a Supercase and a quality overhaul kit. Hopefully you wont need any gears but reverse. Case $295 or so, Overhaul kit $135 Reverse on mainshaft and the idler $100/set Shift forks $23ea. Buy a book and a jar of Vaseline and get to work. We'll help ya.
Note: the Vaseline is for re-assembling the gearbox, not 'getting the shaft'
Old 10-24-2013, 02:01 PM
Shifter (Muncie or Hurst)
I would not over panic yet. Before you go thru the process of yanking the transmission, disconnect the shifter linkage, inspect the threaded studs on the transmission that the linkage arms bolt to. Ensure they are in good shape. Next, set the transmission in Neutral by manually moving the threaded shafts to a straight up position on the side cover. The reverse one will move towards the rear to disengage the reverse gear. Now check and see if it is truly in neutral. If so, the problem is with your shifter and not the Transmission.
Inspect the shifter for wear. If it is the original shifter, you may want to consider installing a hurst competition plus or send that one out to a reputable outfit that can restore the original shifter to spec. If it is a hurst shifter they provide a rebuilding service that is excellent.
Good luck.
Old 10-24-2013, 03:54 PM
jokerZ71's Avatar
Wrench Turner
I'd definitely ck a few things befor snatching it out for a rebuild,unless,you just absolutely wanna a rebuilt tranny.It could turn out to be somethin simple.I always had problems if I had to stop on a hill or incline of any type.9.9 times outta 10,it would hang up.I had the short throw Mr Gasket shifter.
Old 10-24-2013, 06:29 PM
techinspector1's Avatar
Wiki Edits: 326
ZOWIE, it has turned itself into a transbrake!!!!!
Value of a Muncie M-21 NovaSS350 Transmission - Rearend 2 08-17-2012 06:56 AM
muncie stuck in reverse OMARS67 Transmission - Rearend 6 12-26-2011 06:50 PM
Muncie stuck in reverse? Mets63 Transmission - Rearend 4 06-22-2009 07:20 PM
Muncie problems Muncie guru needed chirpn69 Transmission - Rearend 8 04-19-2007 10:28 AM
Muncie 4 speed stuck in Second greasysideup Transmission - Rearend 3 02-05-2005 03:36 PM
