Stuck in neutral?? T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2012, 08:41 PM
Ok so i let a buddy of mine barrow my truck for a but.. well i get a call from him saying that he thinks that the 5 month trans went out... so standing there biting my knuckle in anger because i have never had a problem with it (and after how he told me how he blew the trans in his 2006 trailblazer a few months before) i went over to his work to check it out.. so i get there and start it up put it in drive and nothing i even went through all the gears and nothing does not even try to move checked the fluid still nice and red so sign of metal no burnt smell no leaks TC spins olny thing i have not checked was the modulator seeing how there was no fluid burning through the carb. could it still be bad? or is the trans shot? could not drop the pan because its sitting in the lot at his job
Old 04-18-2012, 09:47 PM
Rule #1--always check the easy stuff first-wich You did checking to see if the converter bolts had not broken or fell out,plus the fluid level,,now check to see if the linkage is ok and shifting properly, Does it roll when out of park?
Another thought-is the drive shaft ok? Is Your bud being honest with You, Possibly he busted it then pushed it there(could happen)or it could have just been coincidental that it let go as he was parking it(hmm),You kinda need that info,,Anyhow if it is nothing exterior to the trans and all pressure is lost I would suspect the convertor then the pump(pressure relief possibly), Better get Your local hook to bring it home.
Jim
Old 04-19-2012, 09:52 AM
It dose not move in park and the converter and flywheel are spinning when the engine is tuning and the shiftter is working it clicks when shifting through the gears fluid looks ok its not at the full line but that should not cause it to not wanna go into any gear this is the first trans I have had do this the last 2 trans that was in it moved when they went out funny thing is that the last 2 went out when I let him barrow it now 3 times?..... and he's going to pay to have it towed home
Old 04-20-2012, 08:44 AM
S10xGN's Avatar
Gotta love a turbo!
Not a valid test... You need to verify the arm on the side of the trans is actually moving. The link (sometimes a rod, sometimes a cable) between the shifter and the manual shift arm may be broken.
Russ
Old 04-20-2012, 12:26 PM
boatbob2
Bad Trans?? or Bad Friend????????????
If im reading this right,your buddy blew his trans up,and you let him borrow your truck?? WHY,if you didnt loan it,you couldnt blame him,stop loaning it ..or GET A NEW FRIEND !!!!!!!!!!
Old 04-20-2012, 03:24 PM
I checked the shift cable its fine and moves with the shifter even checked the rod that its connected to and it moves, lucky for me he decided to buy the truck from me and have the trans rebuilt witch is good seeing how I just bought a new car and how im tired of dealing with it... now I have a garage full of sbc parts to get rid of anyways thanks for all the replys and help
Old 04-20-2012, 07:58 PM
Wiki Edits: 27
it's been a while
Mabe some one who is a trans expert can help but IF I remember right my son had a problem once and we pulled the pan and it was something simple, the linkage from the outside shift arm to the inside actuator.
78 firebird with a chevy 350 and T-350 neutral start only addictivewoodworks Transmission - Rearend 3 03-15-2012 06:11 AM
th350 no seems like its stuck in neutral matt921 Transmission - Rearend 6 01-15-2012 03:18 PM
Stuck in neutral Arrowhead Hotrodders' Lounge 17 12-16-2008 07:48 AM
Neutral Safety Switch on TH-350 nova69 Electrical 5 11-22-2007 04:01 PM
95 camaro stuck in neutral solgood71blazer Transmission - Rearend 2 12-13-2004 01:06 PM
