Stuck nipple - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2004, 01:37 PM
blacklotus's Avatar
Greg
Last journal entry: Wiring begins
Stuck nipple
Well I have a problem. I have a 351M/400 Ford and on the front of the block passenger side there is a nipple in the block for the heater hose. I believe it is threaded in, but I can not get it out.
When I put some PB blaster on it to loosen the oxidation, the fluid goes down in the crevice between the block and the nipple.
I have also put some heat to it, I don't know if I put enough though.
Anybody have any suggestions?
Greg
Old 10-22-2004, 01:55 PM
Tazz
PB Blaster and heat
Your on the right track...Blaster will sometimes take a day or even two to completely loosen the crud so you can loosen the nipple. With the heat you would need to concentrate it to the outside of the nipple and around the nipple where it hits the block and use a hex 6 point box end wrench or socket if it will fit over the nipple. Don't trust a 12 point to grab and not round off the corners!!!
Tazz
Rat Rods Rule!
Old 10-22-2004, 02:22 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
That's probably about 1/2" I.D.. As a last resort you could drill it almost to the threads and use an EZ out, could be pretty risky...
Larry
Old 10-22-2004, 02:25 PM
King of my Man-cave.
That nipple is pressed in.
tom
Old 10-22-2004, 02:51 PM
MI2600's Avatar
Member# 3287
Someone a while back suggested heating the area surrounding the object and then dripping hot wax into the crevice. I tried it a couple times. It worked once...I think.
Old 10-22-2004, 03:50 PM
docvette's Avatar
Wiki Edits: 12
nipple
Doc here
STUCK NIPPLE?? Ouch!!!!!! I just hate when that happens...
Oh, on the manifold....
IF it's threaded and not pressed as Tom said, you might try some penetrating oil, or heat and a Socket and impact gun...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-22-2004, 04:16 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Impact gun should remove it. If that doesn't work the all time best trick is get it hot then crack a can of automotive refrigerant open on it.
Old 10-22-2004, 06:05 PM
4 Jaw Chuck's Avatar
tom
Tom's right, it's pressed in.
You can use a die grinder to grind through the side of the fitting and then use a punch to collapse it when your close to breaking through.
— Han Solo
Old 10-22-2004, 07:36 PM
blacklotus's Avatar
Greg
A lot of discussion on that nipple
Maybe I should explain a bit further. This is a smooth round nipple, can't use a wrench or hex key. It actually turned a bit today with vise grips.
I am inclined to believe it may be pressed in after reading everybodys reply.
So lets work on that assumption. Also if it is pressed in and I get it out what can I put in the place of it to close off the hole.
DOC it is on the block!!
Thanks for everybodys help
Greg
Old 10-22-2004, 07:45 PM
Black Sheep's Avatar
See you on the street...
A freeze plug will work if you can find one the right size...
Old 10-22-2004, 07:47 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
If it is pressed in and you get it to turn with vice grips,grab a small pipe wrench to try and turn it with.You will get better leverage,unless it is in tight quaters.You can measure the i.d. of the hole,or take the pipe to a machine shop and get them to match it with the correct size freeze plug.
Old 10-23-2004, 01:54 AM
Ford sells the proper replacement press in nipple. You will likely need to freeze it to tap it in, it's a snug fit.
— Han Solo
Old 10-23-2004, 02:17 AM
Muscle car fan
well what you need to do is twist the nipple
'74 Gran Torino Project
351W, c6 trans, 9"
Old 10-23-2004, 02:56 AM
docvette's Avatar
Wiki Edits: 12
nipple
Doc here
Maybe a Large (1/2 or so) "Grip type" Easy out down the center of the Nipple, with a Socket drive to twist it while you pull out on the nipple with vise grips??
If you have the room..
Doc
Innovations
Old 10-23-2004, 07:41 AM
My query is, why take it out? If they are in good shape, we just leave them in.
tom
