Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stuck Proportioning Valve
Old 10-25-2012, 11:46 AM
delawarebill's Avatar
delawarebill delawarebill is offline
brakes
i'm not sure what u are talking about.. a light ind????? the valve is stuck.. is that u can't adj it, or rear bks r locked up and wouldn't unlock ??? i just might be as simple as the brake peddle rod is adj'd too long and will not let fluid flow back..
The Following User Says Thank You to delawarebill For This Useful Post:
wrb36usa (10-26-2012)
