Stuck Proportioning Valve
I have a "49 Willys Jeepster Street Rod. It has Disc on the front & Drum on the rear. I just put a new Chrome Master cylinder & Chrome Booster & Brass Proportioning Valve on it and the Valve is stuck. The light indicator is on. How do I get it unstuck? Everything is now mounted on the car and master cylinder was bench bled. Thanks
brakes
i'm not sure what u are talking about.. a light ind????? the valve is stuck.. is that u can't adj it, or rear bks r locked up and wouldn't unlock ??? i just might be as simple as the brake peddle rod is adj'd too long and will not let fluid flow back..
Open a bleeder opposite the end you last bled.Push slowly on the brake pedal until the light goes out, close the bleeder. It should be centered.
I have resolved the problem.
Thanks |
That solution solved the sticking problem. Many Thanks.
Maybe you can help with a new brake problem. I now have a good pedal but stopping the car is very difficult. It is acting like there is no power brake since I changed from an 11 inch booster and 1 1/16 bore master cylinder to a 7 inch booster and a corvette style master cylinder. I really seem to just have manual brakes with very little stopping power. |
http://www.mpbrakes.com/uploads/documents/optomize.pdf |
That info was really helpful. Wish I had known some of this before I bought the 7 inch booster.
Thanks |
I have the Corvette style Master cylinder. guess I will need to go to a larger booster.
Thanks |
| All times are GMT -6. The time now is 07:04 AM. |
