Stuck Proportioning Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2012, 08:49 AM
wrb36usa's Avatar
I have a "49 Willys Jeepster Street Rod. It has Disc on the front & Drum on the rear. I just put a new Chrome Master cylinder & Chrome Booster & Brass Proportioning Valve on it and the Valve is stuck. The light indicator is on. How do I get it unstuck? Everything is now mounted on the car and master cylinder was bench bled. Thanks
Old 10-25-2012, 11:46 AM
delawarebill's Avatar
brakes
i'm not sure what u are talking about.. a light ind????? the valve is stuck.. is that u can't adj it, or rear bks r locked up and wouldn't unlock ??? i just might be as simple as the brake peddle rod is adj'd too long and will not let fluid flow back..
The Following User Says Thank You to delawarebill For This Useful Post:
wrb36usa (10-26-2012)
Old 10-25-2012, 06:47 PM
Open a bleeder opposite the end you last bled.Push slowly on the brake pedal until the light goes out, close the bleeder. It should be centered.
The Following User Says Thank You to enjenjo For This Useful Post:
Old 10-26-2012, 06:53 AM
wrb36usa's Avatar
I have resolved the problem.
Thanks
Old 10-26-2012, 06:59 AM
wrb36usa's Avatar
That solution solved the sticking problem. Many Thanks.
Maybe you can help with a new brake problem. I now have a good pedal but stopping the car is very difficult. It is acting like there is no power brake since I changed from an 11 inch booster and 1 1/16 bore master cylinder to a 7 inch booster and a corvette style master cylinder. I really seem to just have manual brakes with very little stopping power.
Old 10-26-2012, 07:11 AM
Maybe this will help.
http://www.mpbrakes.com/uploads/documents/optomize.pdf
The Following User Says Thank You to vetteman For This Useful Post:
wrb36usa (10-29-2012)
Old 10-26-2012, 05:42 PM
In my opinion, a 7" booster is just barely better than nothing. A 7" booster will produce less than half the boost than a 11" booster. And if you have a bit of cam, with low vacuum, it just makes it worse. The 1 1/16" bore master doesn't help either with a small booster. I have had some success switching to a 7" dual diaphream master cylinder in a case like yours, it still will not put out as much boost as a 11" booster, but it's much better than a single diaphream 7" booster. If that is not enough, you can change to a 1" Corvette style master cylinder, it bolts right in, and improves the mechanical advantage, at the cost of slightly more pedal travel.
Old 10-29-2012, 05:16 AM
wrb36usa's Avatar
That info was really helpful. Wish I had known some of this before I bought the 7 inch booster.
Thanks
Old 10-29-2012, 05:18 AM
wrb36usa's Avatar
I have the Corvette style Master cylinder. guess I will need to go to a larger booster.
Thanks
Proportioning Valve rusty duck Suspension - Brakes - Steering 4 07-20-2011 08:24 PM
Proportioning Valve is stuck Footstomper Suspension - Brakes - Steering 3 01-13-2011 07:41 AM
proportioning valve 2manyhobbies Suspension - Brakes - Steering 4 02-18-2006 03:06 PM
proportioning valve fred56 Suspension - Brakes - Steering 11 12-21-2005 02:46 PM
S-10 Proportioning Valve TurboS10 Suspension - Brakes - Steering 5 01-03-2003 10:42 AM
