Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stuck valve covers
Old 08-21-2012, 09:16 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Originally Posted by 302 Z28 View Post
Don't you just despise people gluing everything on?. Once when I was working as a mechanic at the local dealership I was given a recheck job that another mechanic who had quit did. It was an engine replacement that had gone bad. He had literally used the 3M Yellow weathership adhesive on everything. I had to chisel off the oil pan, timing cover, intake manifold, water pump, and valve covers. Oh and he also used the yellow snot on the distributor also.
Vince
If it was a Ford 'Y' block, that's about what it took to stop the always deformed valve and valley covers from leaking. Then there was that external oil pump tube.
Irelands child
