Stuck valve covers
Anyone Know any tricks to remove 350 Comp Cam Chevy valve covers that appear to be glued to the valve cover gaskets?
As long as all the bolts are out, pry them off
Ontario Rodders |
Some well placed light blows from a dead blow mallet will loosen them up.
We all know 'that guy' I think.
To the OP: you can use a dead blow hammer or a piece of soft pine with a hard faced hammer; should come right off. If they're stamped covers, you may have to clamp a piece of bar stock in a vise and tap the flange flat again after you rassle em off. |
You can also help some by slipping a razor blade in between the valve cover and the head wherever possible and just cutting the gasket. After that the valve cover will come off easier.
| How do I find out if a valve is stuck? | Chevy350Sb | Engine | 2 | 12-16-2009 09:53 AM |
| Stuck valve | MuscleCarGaL | Engine | 8 | 07-29-2009 07:42 PM |
| stuck valve problems | hammerhead | Engine | 7 | 10-21-2008 10:33 PM |
| EGR Valve in the way of new valve covers | Jag Daddy | Engine | 9 | 05-16-2004 11:05 PM |
| Stuck Valve | Daved | Engine | 4 | 07-16-2003 07:39 PM |
