Stuck valve? Ford T-bird - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2008, 08:22 PM
Im helping a friend with 70 T-bird.Its a 429 with about 75,000 miles on it. It was sitting for about 18 years in a garage we got it running (marvel mystery oil in the cylinders, changed the oil, fresh gas cranked with the plugs out then started it up) It seems to run ok at idle dosent smoke and the oil stayed clean but its got this miss when you put some load on the engine. I changed the plugs and wires new points checked the dwell new cap and rotor but the front plug drivers side dosent seem to be doing anything theres spark there too but when pulling off the wire the idle just stays the same and the plug seems slightly wet (seems to be oil, very little) Is it a stuck valve ? I was thinking of pouring some Marvel mystery oil down the carb while it was running to see if it would clean them off. I havent taken off the valve cover yet.Anything else I can try? Could it be the rings? If so wouldnt I have blue smoke from the exhaust (theres no smoke blue black white) .
Old 11-02-2008, 09:50 PM
stuck valve
Pull the valve cover and look at the rockers. A compression check is in order . Happy sleuthing.
Clint
Old 11-02-2008, 11:06 PM
pull the covers and hit each valve with a rubber mallet, if a valve is stuck that should free it up, gl
Old 11-03-2008, 07:50 AM
onebadmerc's Avatar
I need a bucket of arc sparks
That will pop the keeper and drop the valve, don't do it unless you want to pull the head.
Old 11-04-2008, 06:55 PM
Bent pushrod is the culprit. I ordered a new set. What is the procedure to
set the rocker arms after I install the new ones?Its naturally a hydraulic cam.
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
stuck valve problems hammerhead Engine 7 10-21-2008 10:33 PM
Ford 272 Distributer is stuck ?? jimcar-9 Engine 8 06-12-2007 05:37 AM
B&S intake valve stuck open m1e9r5c6 Hotrodding Basics 7 04-30-2004 04:13 AM
ford hi-po valve train fordracing Engine 6 03-17-2003 07:56 PM
