Stud Gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2007, 10:15 AM
Stud Gun
Here's the deal. I need to pull out some dents in my frame before it gets coated. I've been welding on a bolt to the dents and then pulling the dents out with a slide hammer. It has been working pretty good...but it is way to time consuming. Plus, because of the fact that the bolts which need to be used are 1/4'' (I cut the head off the bolts and weld the side that the head used to be on to the dent...the slide hammer screws onto the threads of the welded bolt), it doesn't allow you to weld on like 15 studs to the dent then pull it out. Not being able to pull out the dent with numerous studs creates a bumpy surface which needs to be blended with a flap disc until it is smooth.
I was thinking that a real stud welding gun would work on my frame...what do you guys think? I don't want to shell out $200 and then find out that it will not work. I have seen them used on auto body panels...but never a frame. I was even thinking of using a stud gun to weld on a stud, then heat up the surrounding area of the stud with a propane torch to give it a little help to pull the dent out. The only way I see why it wouldn't work is if the spot welder doesn't weld the studs on strong enough to pull out dents in thicker metal. Please help, post your comments.
Old 09-17-2007, 09:52 AM
Please post...
Old 09-17-2007, 10:09 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you use the heavy studs and a good puller you can attach to a frame and move it..one may need to apply heat to get it to move and use quite a bit of force..like a 10 ton porta power..stay out of the way of this as if they come off or break one can be badly injured..Better be safe than sorry.
A good quality stud gun with a good puller such as an H&S is a good investment..I do not use mine all that much but when I need it I need it..
Sam
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
