Stud Gun Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2009, 10:24 AM
Stud Gun Problems
Hey,
First off i will readily admit I am a newby. I have a harbor freight stud gun but am have trouble with the studs coming off when pulling on them. Am I not holding the trigger long enough? Just trying not to warp the panel with too much heat. I am hold the trigger for about 5 seconds - 1,2,3,4,5? Any suggestions appreciated.
Thanks in advance
Old 06-23-2009, 11:22 AM
stud gun
If you are pulling whole stud off then they are not welding on good. Hold longer or clean area better. If you pull stud and make hole in panel you held too long. Practice on a scrap piece until you get the timing right. Should be a nice cherry red around head for a second. They don't like long extension cords or smaller wire ones. Too much voltage drop.
Old 06-23-2009, 11:46 AM
Thanks. I was using a extension cord.
Old 09-18-2009, 01:45 PM
Im trying to have an idea!
did you ever master the gun? Just wondering because I also have the stud gun from HF. My brother used it and said the studs were not sticking right. I am just thinking user error. I believe he was also using an extension cord. I would not see how this type of product could be faulty, simple enough to make/ design.
Old 09-18-2009, 03:08 PM
I don't have the HF gun, but on mine, they say only hold the trigger for about a second at the most. I used to hold for a full second and they'd stick well, but I've found that a bit over half a second will get the studs to stick well enough for pulling but easy enough to twist off without getting out a grinder.
Old 09-19-2009, 01:22 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Cleaning and good contact are paramount.
The quality of the materials the studs are made of might be suspect if you're holding for 5 seconds and still having sticking issues.
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
Spot weld w/ stud gun? jcclark Body - Exterior 7 05-19-2007 12:16 PM
Newbie Paint Gun Recomendations dannyg402004@yahoo.c Body - Exterior 2 04-28-2006 10:21 PM
Proeblems with Finishline Gun rcm800 Body - Exterior 11 04-27-2006 03:32 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
