John, is this what you were talking about?
Brian >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> “Basics of Basics” Dent pulling By Brian Martin These are a few tricks to pull a dent out when you have no access to the back. There are a million and one ways to do it, these are just a few. I use these and others all the time, there are few right and wrong ways to get it done, just as long as you can get it done. I made these tips up for those who don’t have a stud welder or other electric style pullers, but you will still need a MIG. They are also used instead of a stud welder if you had one. These methods will pull much thicker metals and or dents that have more resistance to pulling like where you will find body lines. The number 2 method is particularly good for where you have a long body line that is pushed in. You can weld pulling tab right on the body line and gently pull out a long area bringing the line right into shape even on strong metal. The one warning I must give you is that you have to remember that you are MIG welding the tab on. If you pull to hard on the tab or the washer that is welded on, you will tear the metal! If you do, well you will just have weld it up. It is not the end of the world, but you will want to avoid it. I can’t stress this enough, these tips are not for little shallow waves or something. They are for serious low spots, where you must get it up a pretty fair amount, it is not worth it to get a fraction of an inch. They can be used for this, it is true, but it takes a good long while using the methods to get that proficient at it. After using the “tool” carefully cut the weld thru the middle with a die grinder and 1/32” cut off disc. Then grind the little bit of weld you leave off, it is that easy. The first (fig 1) is a simple old trick, you weld a large washer to the low spot and either hook some sort of slide hammer to it or using leverage like in the diagram. I usually use constant even pressure with leverage like the diagram for better control. In fact, I seldom use anything like a slide hammer on anything like this because it just doesn’t allow you enough control. In the diagram I have a long pry bar that is stuck into the hole on the washer and laid across a piece of wood. Applying pressure to the back of the bar will pull up on the dent. Apply the pressure and then tap on the high spots (or even level spots) that are right around the low spot, it will usually come up pretty easily. The second tip (fig 2) is a trick that has worked wonders for me. This trick works so good, I have taught it to many guys in the shop. This method is the method of choice even though we have some very nice equipment for doing such things. It is just perfect with plenty of control and gets the job done fast. I have made up these “taps” for pulling from little pieces of sheet metal. They are about 20 gauge metal and approx. one and a half by three and a half inches. I have welded a few short beads to them on top to hold the Vice grip from sliding off (fig 2b). The tool I use to apply pressure is a “Pogo stick”, an old bodymans tool that has been around for years. They are pretty inexpensive, I think about $100.00. You could make one pretty easy if you wanted to. The chain that comes with a single hook on one end (fig 3) and double hook on the other (similar to fig 4). After the tap is welded on the car and the Vice grip (you’ll notice the one I use has curved jaws and I believe it is for pipe) is attached I just hook the single hook on the front of the Vice Grips where they pivot (fig 5). The Pogo stick has hooks on it (fig 4) where you hook the chain on. I use the bottom hook for more leverage about 99 out of a 100 times. The Pogo stick has a metal “foot” with rubber on it at one end and a bicycle type handle grip at the other. You put the foot on something solid like the spring perch in this case. Hook the chain on and apply force going down (sometimes up, depending on where you can put the foot) while tapping on the metal surrounding the dent. Gentle constant pressure is always better than something like a slide hammer. These two methods provide that for you.
Asked and answered..
elsewhere, but I'll ask again.
I have a freakin' $650 mig welder. Can I stick the freakin' stud in a drilled contact tip and use it like the stud welder? Thanks for any freakin' answers.
| is this welder any good?? | michiganjoe | Body - Exterior | 10 | 11-23-2006 07:57 AM |
| My first post and a welder question | Bugs | Garage - Tools | 17 | 11-08-2005 02:49 AM |
| Hobart Champion 4500 welder | sotxpanrider | Garage - Tools | 2 | 03-06-2005 09:07 AM |
| pontiac 389 broken rocker stud | tree_entz | Engine | 4 | 06-08-2004 12:29 PM |
| Arc welder ~VS~ Mig Welder | ChrisMiddleron | Electrical | 15 | 07-08-2003 07:31 AM |
