I had a 60 Lark with a small block chevy in it, the stock Stude trans is an early borg-warner with a Ford style bolt pattern and input shaft if I remember correctly. I used a muncie 4-speed (chevy three spd would work) had to fabricate the clutch linkage, and engine mounts, replaced the driveshaft with the correct length from a pile of shafts at the bone yard. The stock Stude rear is an early 50's Ford type unit and will break(spent many evenings replacing spider gears, untill a 9" 57 Ford rear came along).
Also the 259-289-304 engines were Studebaker engines, they looked similar to early fifties Caddies.
