Stuff I work on at work :) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2003, 06:55 PM
Military Mechanic
These are what I work on at work. Amazing the amount of differences between these and a 350. Working on these so doesn't make that good with a 350 BTW they are 903 cubic inch, turbo charged ,v config ,aftercooled engine. Make about 600 hp at 2200rpm and 2000 ftlb torque at the same. Move the Bradleys pretty quick at up to 60mph which is way faster than you want to really go
The guys in the picture are some of the guys who I supervise from california. He's into imports and is quite a good racer with em but doesn't know much about chevys and such. Hoping that working with block blocks like these will rub off on him
Eric
Old 09-28-2003, 10:49 PM
Nos's Avatar
Nos Nos is offline
do u think you can stick that in a car?
Nos
Old 09-29-2003, 05:32 AM
Madd Syntst's Avatar
American Madd Man
Hmmmmmmmmm, how do you chop a tank?
Old 09-29-2003, 07:32 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Now THAT'S fine machinery. Did you know that the old dual range hydramatic tranny was originally designed for use in one of those? No wonder it saw so much service in puny little dragsters.
Incidentally, thank you for preserving our freedom.
Old 09-29-2003, 08:50 AM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Here on post
Hey Eric, Whats the building number of your motor pool. I'm with the Fire Department here on post. I'll stop by an see ya sometime. I'm out at the Hood field station.
David
Old 09-29-2003, 09:34 AM
4 Jaw Chuck's Avatar
Originally posted by willys36@aol.com
Thank you for preserving our freedom.
That goes double for me too. Isn't it interesting that there are hotrodders keeping machinery running in the most critical of services, I imagine the crew that maintains Airforce 1 are the same.
I met a fine gentlman on this very forum that had a hand in designing AF1 and he's a rodder too. Hotrodders will rule the world...or at least keep it running and making it go faster than designed.
Outlawed tunes from outlawed pipes
Old 09-29-2003, 01:08 PM
Military Mechanic
I work in the 91st eng motorpool at hood road and hell on wheels. If you look thru the parking lot and see a 79 primer gray camaro its mine
Eric
