Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stuffing BBC into a little S10
Old 08-06-2008, 09:15 AM
Double_v23's Avatar
Double_v23 Double_v23 is offline
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
The Big Block should bolt in where that Small block used to be. It will be taller and wider at the top, you will need to custom build a set of headers or maybe you could go with a fenderwell header setup since you don't have any inner fenders.
