Stumble off idle in park, carb or ignition problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2004, 04:17 PM
Muscle car fan
Engine is a 351W
duraspark ignition
670 Holley street avenger out of the box and onto the car
air gap intake
4 hole 1" spacer
symptoms
in park rev engine slow, nice response
in park with vac adv connected, rev fast, stumble
in park with vac adv discon, rev fast, stumble
timing was set by the advance till it pings then back it off till it doesn't method (not the best i know)
wondering what might be the problem, from this description can anyone tell if it would be ignition/timing related, carb related, or vaccum leak somewhere or something else?
havn't had the car to the track to give it to see if in gear it does the same
anyone know what the prob could be?
'74 Gran Torino Project
351W, c6 trans, 9"
Old 05-16-2004, 09:55 PM
DoubleVision's Avatar
it sounds as if your carb needs a bigger pump shot or the pump is faulty.
Old 05-18-2004, 07:03 PM
73chevyhelp's Avatar
check the timing, make sure dis is in tdc. then go to the carb. and is the stumble at initial throttle or bad idle throughout the throttle?
Old 05-18-2004, 10:29 PM
Muscle car fan
stumble is only bad off idle when you jam it, and i think only off idle
351W, c6 trans, 9"
