stumble on take off - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2006, 09:00 PM
stumble on take off
i have a 1972 hevy pickup and it has a 350 four barrell and lately it has been stumbling on the take off and thats the only time it does it. runs perfect the rest of the time. i have rebuilt the carberator but it still does it does anyone have any ideas of what it might be?
Old 10-12-2006, 09:11 PM
Did you clean out the idle and transition systems real well? Sometimes a little something will get in there and partially block a passage, and that can cause an off-idle stumble.
Crummy gas can also cause a similar stumble.
Old 10-12-2006, 10:22 PM
underdog305's Avatar
It sounds like it's going lean on initial acceleration. Check your accelerator pump. You need that extra splash of gas when you get on the pedal. Shut off the engine. Pull the aircleaner off, open the throttle while looking down the throat. Look and listen for the spray of fuel. If it just dribbles.. Theres your problem. If it pumps real late that could be it too. Depending on the carb you can schedule the pump to squirt sooner or later. Check your timing too, if its to retarded that will do it as well.
351w off idle stumble maby ???? smitty299 Engine 8 05-13-2005 08:14 AM
off idle tip in stumble 6speedwagon Engine 2 07-27-2004 09:47 AM
Stumble off idle in park, carb or ignition problem Dubz Engine 3 05-18-2004 10:29 PM
The Stumble Theory RayBaby Engine 4 09-09-2003 09:56 AM
New member w/ Holley stumble off throttle NRens Engine 7 03-04-2003 08:17 PM
