stumbling 2.9l - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2008, 06:52 PM
stumbling 2.9l
i am having troble with my 86 bronco ll stumbling hard when warmed up. emissions passed really great, cats are not bad(took them off and still had the problem), intake air temp sensor replaced, timing is good. its something temp sensitive, runs fine when cold. what might this be???!!!???thanx a lot all help is appreciated
Old 05-11-2008, 06:59 PM
Thumper_Pumper's Avatar
muddin maniac
Last journal entry: moter
ur thermastat maby ?
Old 05-11-2008, 07:11 PM
stumbling 2.9
the sad thing is NNNOOOOO i didnt even think of it thanx a yillion
Old 05-11-2008, 07:16 PM
muddin maniac
no prob bud
Old 05-13-2008, 02:03 PM
thermostat is replaced and its still screwy
Old 05-13-2008, 02:29 PM
Wiki Edits: 31
try the coolant temp sensor.. sounds like it's reading a low coolant temp, causing it to stay in open loop, which is designed for warm up and will run rich on a warmed up engine.
Ford Bronco 2 v6 2.9L - No SPARK debbiewi Electrical 16 07-24-2013 05:14 PM
Engine Stumbling pete379 Engine 7 07-31-2005 05:42 PM
'87 Bronco II 2.9L montana1489 Engine 4 07-11-2005 07:37 PM
wow new edelbrock carb stumbling! Trav Engine 17 06-02-2004 05:56 PM
Carb problem...stumbling 383MontecarloSS Engine 8 02-27-2004 12:09 PM
