stumbling in high gear, low RPM , sounds like metal and rocks - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-24-2012, 07:18 PM
cool deal
I got the distributor play resolved, for now atleast -
I added another gasket for some space
However, I can hear this weird rattling sound coming from my exhaust
I looked around a bit to see if something is loose, and I cant find anything. It really sounds like the rattling is coming from inside my engine
Something else, dunno if this is normal or not,
but I took my valve covers off to check my rockers, they sounded noisy , so I adjusted them, but theyre just noisy ( Scoropion roller rockers) from what ive heard
And I noticed some small bubbling at a few of my head bolts... like small bubbles coming through my head bolts... is that water escaping from my water jackets thrgouh the head bolts???
I didnt retorque my head bolts after I installed and torqued my heads...
For the timing, I had tuned my timing down to 18* or so base timing, and had a total of about.. hmm 35*ish total.. which eliminated my detonation we talked about earlier
But, when i stepped on the gas, it TOTALLY hesitated and wouldnt even spin the tires.
So I pulled over, advanced my dist. a little, and wala perofrmance was back.
ZCame home and checked timing - its about 21* base and 39*-40* total...
is that too high? Fbird emphasized 36* max.. but theres no power with 36* max..
what should my vacuum be?
ahh all this crap
  #17 (permalink)
Old 06-25-2012, 10:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Ocean-Angler
cool deal
ahh all this crap
The better performance is coming from the increased initial timing, not the total timing. Limit the total to give you 36 degrees or so, with whatever initial timing that gives you the best performance.
Are you using a vacuum advance? If so, you're in the area where ported vacuum will prolly work better than manifold vacuum unless you are determined to tune it to work w/manifold vacuum.
Edit- The head bolts need to have sealer applied to the threads, that's likely where the seepage is coming from. Re-torquing the heads might help. Or not.
Vacuum is dependant on a few things, but the more radical the cam, the less vacuum you'll have.
  #18 (permalink)
Old 06-25-2012, 01:02 PM
I had used the sealer on the bolts, maybe I didnt use enough..?
so your guess would be that the small bubbling is air/water escaping going uip the bolt..?
Its a non vacuum advance MSD btw
  #19 (permalink)
Old 06-25-2012, 01:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That would be my guess, yes.
RPM to Low in gear prettyboyced Hotrodding Basics 6 03-11-2010 02:21 PM
Centrifugal supercharged 5.9 dakota makes low boost in high gear? ForceFed86 Engine 2 06-30-2009 10:08 PM
rattling at low or high rpm IROC-russ Transmission - Rearend 4 09-15-2004 11:50 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
low rpm high torque bluetruck Hotrodding Basics 9 07-09-2004 11:44 PM
