Stumped - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-18-2009, 10:32 PM
I just thought of a nothere thing that I use to run across, the intake gasket
shifting just enough to pull in sone oil. just a thought.
  #17 (permalink)
Old 04-19-2009, 05:44 AM
DoubleVision's Avatar
The trans is a TH350, fresh rebuild. I bypassed the modulator and checked the line for fluid, it`s dry. I looked in the fuel filter with it idling and still seen alot of trash. I`m starting to really lean towards fuel system contamination.
The old tank had so much trash and varnish the prefessional cleaning didn`t get it all out. We installed another tank that still looked new inside. However, the fuel line I`m sure has trash as it`s very obvious to see in the filter. Maybe if we keep running it the issue will resolve itself as the fuel system gets cleaner. I think I`ll run some seafoam in the tank, keep a eye on everything else and leave it be for now. Whatever`s causing this has to come to light sooner or later. Thanks guys.
Stumped! Need help with stumbling TPI motor DaSouthWon Engine 53 10-27-2008 09:34 PM
Still Stumped 10mikeymike Engine 13 09-10-2008 11:59 AM
stumped with wagon. 68novafan Electrical 7 04-06-2006 08:20 AM
351C wont stay running after revving......stumped?? Steve-0321 Engine 6 03-23-2005 09:36 PM
Need FI help. I am stumped so far! Siggy_Freud Engine 17 01-28-2005 06:22 AM
