Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stumped on this part?
  #26 (permalink)
Old 08-26-2012, 05:52 PM
handy7rick handy7rick is offline
Most likely you arent getting any fire.You can run a hot wire with an inline fuse to the hot wire on the distributor.Try not to do too much cranking on that new rebuild.It needs to fire right up and run 1500 to 2000 rpm for twenty minutes for proper break in checking for leaks and oil pressure and temp readings.
