Stumped on turbo 350 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2012, 10:17 PM
350 turbo all positions pull forward neutral and reverse,park binds like it's pulling. What's going on?
Old 03-03-2012, 09:10 PM
mike, 70 ss el camino
Sounds like your forward clutches have welded/melted themselves together. Causes a very noticable binding when accelerating in park range and tries to pull forward at all times when out of park range. Severely burned fluid goes along with this symptom.
One other possibility (check this first), especially if the fluid is not burned: The selector shaft in the valve body has come loose and has settled in one of the forward (drive) positions. This shaft is moved by the mechanical back & forth of the shift lever itself.
400 turbo transmission 4x4 truckster Transmission - Rearend 5 02-12-2007 08:20 PM
400 turbo transmission? kongmen Transmission - Rearend 2 07-18-2005 01:14 AM
TURBO 400 TRANSMISSION wiretwister Transmission - Rearend 6 10-21-2003 06:52 PM
Turbo 350 Transmission my59f100 Transmission - Rearend 0 07-17-2003 07:22 AM
350 turbo transmission nelson350ss Transmission - Rearend 5 03-20-2003 05:22 PM
