stupid fwd - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2005, 10:05 PM
bowtiebadboy's Avatar
first timer
stupid fwd
OK before i start please don't stone me its a daily drive while i work on my 55 Chevy truck
today i adjusted the linkage and triple checked everything so i started to back out and it felt like i was running over something so i stopped and checked it out there was nothing so just tried it again and it still happened but then it was fine so i just moved it out of the driveway into the front of the house with out a problem
but what could make it feel like im running over something im 110% sure there was nothing under the car
Old 08-07-2005, 11:11 PM
montea's Avatar
tryn to learn
uhm i think you need to give some more info then that like what kind of car, since its in the transmisson rear end forum im guessing its the tranny? standard or auto? linkage for what?
Old 08-07-2005, 11:19 PM
first timer
o sorry i had it all typed out but i delete it to say it differently its a 1985 dodge omni glh with a 5 speed manuel
the shift linkage
i think it would have to be the tranny because the motor runs fine otherwise
Old 08-08-2005, 10:40 AM
JamesRS's Avatar
From the description that you gave it sounds like you might have a busted motor / transmission mount or your E-brake may be sticking after the vehicle sits for a while. If the motor or trans mount is broke, then when you accelerate to get the vehicle moving then the motor or trans may be lifting off of the broken mount and dropping back down giving you the feel that you bumped into, or ran over something. If the E-brake is sticking, then when you start the vehicle after its been sitting for a while, the brake shoes jerk release from the rear drums and it will also feel like you have bumped into, or run over something.
Just a few things for you to check out.
Old 08-08-2005, 08:23 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
CV joint?
I would open the hood and jack up the front of the car, and just start trying to move stuff like the CV halfshafts, the engine if one of the mounts are broken. with the front off the ground trun each front tire and check for play in the driveline, you should be able to do this while looking under the car and looking over the fender at the engine.
Having someone else looking while doing these things will most likely help.
GM V-6 engines for FWD A-body models tcruise Engine 1 04-02-2005 09:23 AM
Mating FWD Toyota Transmission to GM 60 Degree V6 Motor dmc12mk3 Transmission - Rearend 3 11-29-2004 03:17 PM
ok i'm young and lost mathjew Hotrodders' Lounge 7 11-27-2003 06:03 PM
Stupid Gearhead stories Cyclone390GT Hotrodders' Lounge 33 09-19-2003 09:10 AM
FWD 3800 into rear - C5 Vette susp? hotrod_tommy Transmission - Rearend 2 03-24-2002 05:03 PM
