Stupid loose window. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2011, 05:57 PM
HerbMarshall420's Avatar
I can not find any useful info on this.
My passenger window (01 accord) seems to be loose.
The lower the window in the door the "tighter" it seems.
The higher it gets the "looser" it gets.
When it gets about 1 - 1.5 inches from fully closed there is a metal pop sound, the window moves slightly forward, and it does not seat in the seal properly.
I took off the door panel and nothing looks out of place, however it's fairly hard to see inside.
Would swapping a new regulator fix the problem, or should would the problem be in the track?
Ideas?
Old 04-13-2011, 07:14 PM
el pollo's Avatar
It's shady under this tree...
I had the same problem on my wife's Montana. Turned out the rubber guide towards the back of the door came loose, and did exactly what you are describing. But mine went even father and the window fell down once when I closed the door. The pop sound is the window making contact with the metal tabs that hold the rubber guide in place. It presses up against it as the window rolls up, and when it clears, the window "pops."
1937 dodge coupe 3 window or 5 window jackie bowman General Rodding Tech 6 07-28-2010 08:24 AM
32 Ford 3 window window mechanics Tansmith Hotrodding Basics 2 10-24-2009 08:37 AM
Window channels and removing vent window Jackyl Interior 11 10-10-2007 07:01 AM
can't get the tie rod loose trident Suspension - Brakes - Steering 4 05-21-2005 11:02 AM
Interior window trim (frames) for 34 5 window Ford Ken@Ft. Lauderdale Hotrodders' Lounge 1 03-10-2002 05:16 PM
