I have a crap load of old da paper (and long for for that matter) that has no adhesive from the days when you sprayed it on (or before that it was in a tube, yes I am old!) does this glue still exist? I just went thru a 3m catalog, nothing.
I just googled it the key words DA glue sandpaper and got nothing, I am thinking it's gone for good. I will have to get creative. :mwink:
Are you sure that 3M doesn't make it anymore? I'm pretty sure they do. I do a have story...I know...not again...but anyway. Years ago i had an 8 inch sanding pad and not unlike the paper that you have, the paper that I had needed that glue...I was out and had to get the job done...Now, it's middle of summer in Canada and the bugs where horrid, I had a box of those fly strips in the shop so that I could control the insect problem to some degree...well, I took one of those fly strips, they are sticky on both sides, cut it up and stuck it to my sanding pad and the paper hung on as good as if I had glue and one application lasted for about 6 sheets of paper...the cool thing was that it was easier to clean than the glue, just peel the fly strip off and put on a new one.
Proof that necessity is the mother of invention...or in this case the distant uncle of improvisation.
Don't know if this helps you Brian, don't know if you can buy those fly strips anymore either.
Good story Ray,I too am old enough to remember that.We can still get the fly traps and we hang them in opposite corners of the booth starting in august to oct.Nothing worse than a fly divebombing into your last coat of clear or finding them dead in the middle of the hood after a bakecycleain:
Do you think maybe some 3m spraybomb interior glue might work?Obviously you wouldn't want to leave the sandpaper on it for days on end but I think it could work for short periods of time as long as you clean it off when your done for the day.
Look under feathering disk adhesive, there's quite a few. 3M makes the best stuff, IMO, I bought some at my paint supplier. Summit carries the stuff: http://www.summitracing.com/parts/TRM-8051/
LOLOLOLOL, Dan, thank you so much, this cracks me up! Like the discussion about people posting questions "they could easily find with a search" I wasn't using the right search words! LOLOL, Feathering disc adhesive, not "DA glue" LOLOL This is funny stuff!
When I went to your link and saw that tube I just about fell off my chair, "Feathering disc adhesive" LOLOL my God I must have squeezed the last drip out of a dozen cases of that stuff! LOL
Yes Brian, when I read Dan's post....I just thought damn, why didn't I remember the right name for "DA glue"...LOL...had no trouble remembering fly paper though...LOL
Here is a perfect example of why we can't give someone a hard time for asking a question on a forum that could "quickly be found in a search". I have been in this business 35 years, used untold amount of those damn tubes of "da glue" and then when it went to spray, WHOOO HOOO, then onto self adhesive and then velcro! I did a search, I looked through my 3M catalog using the index and then thumbing through it, saw nothing!
I waste everyone's time here posting on something that could have easily been found in a search.
As I said before to Kelly, I am not busting his bawls ( like how I got past the censor on that on? ) I have seen that brought up many times, he is just the latest that's all. We are all just talking, giving opinions. I just find it so funny as I read Dan's post like a slap to the forehead, my God how could I possibly be so far off in my search! A simple search for a simple product yet I came up with nothing because I was using the wrong key words.
Thanks "Typical Car Guy", I have been told that I have a story for everything...probably because I've done some things in my life that makes me wonder how I made it this far...LOL.
Today must be Alberta day, so far we've a had a new member from Devon and 3 more posts, including yours from the best Province in the Country...Damn I miss Edmonton. I've only been to Lethbridge once and had a great time...that's another story from many years ago, my wife reads some of my posts and even though that was before I met here, I better just save that one...LOL.
when that spray disc adheasive came out I remember thinking ,this stuff is the sheet..until then it came in a can and you squeezed it onto the pad it was basicly pine tree sap and it smelled like it too man that stuff was gooey...Every time we got a new guy they would eventually put to much on the pad and the paper slid off .I almost fired a guy for putting to much on and then letting the DA spin freely without being on the car...that paper slung off and stuck on the side of my face i was so peed off that goo was in my hair and everything..
that same old pine sap glue is used to stick the top on a glass slide when making slides for use with a microscope..
theres a repositioning spray glue they use at the arts and crafts store that'll work if you dont to want for the mail...
I mentioned this thread to an another gray haired old dude at work (the only other gray haired old dude there) and he told me he has a brand new ("NOS" LOL) tube of "Feathering disc adhesive" that he is going to bring for me tomorrow.
We used to put a line of glue on the pad in a circle starting outside on the disk and working to the center. It didn't take much, the you would slap the disk on there, pull it up a few times until the glue was spread out a bit and tacky. Only the heavier 36 grits would fly off if you did it this way.
Dan, it's so funny reminiscing about something so mundane. But it's so interesting how those memories start cooking in your head. The first time I saw that tube you posted of "Feathering disc adhesive" that was the first image that popped into my head, the squirting of the glue, then rubbing it around with the sanding disc and then peeling it off and slapping it down a few times. My God now many times did I do that? Was it simply thousands or was it tens of thousands? I don't know but it was a LOT.
Dan, another common practice was to "slap" the paper device made from a piece of 1/8" welding rod to knock the primer out of the paper so it would keep working. I have one out in my shop made from brazing rod that I have owned since my days at "The Early Ford V8 Shop" doing full on restos full time in 1978-79. It's worn almost half thru from the slapping on the paper! Can you imagine how many times you would have to slap sand paper to wear this rod thru? And we are talking 180 blocking primer, good memories I'll tell you that.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
