Stupid question of the day, DA glue? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-02-2013, 07:54 AM
Originally Posted by carolinacustoms View Post
Geez Brian, do I have to tell you everything? All you have to do is staple the paper to the DA pad...............
And for the record I take no offense to anything said on this forum. I don't agree with everyone all of the time, but we all have opinions, and preferences. I have found that a few people seem to be very defensive (the "I'm right and everyone else in the world is wrong, because I am the only one that can do it right and my way/work is perfect" type), but to me it is all about the diverse information you can get from different people with different methods.
Kelly
Thanks Kelly.
  #17 (permalink)
Old 08-02-2013, 08:45 AM
Faith - Respect - Trust
Originally Posted by gearheadslife View Post
but but he should've just used a simple google search..
no??????????????
LOL...Now, Now, Brian had a brain fart just like I did...I couldn't have done a google search either...you need to remember the right name name to do a google search...I forgot too...Dan didn't, he brought us back to the old days with "feathering disc adhesive".
Ray
  #18 (permalink)
Old 08-02-2013, 10:12 AM
Originally Posted by 69 widetrack View Post
Are you sure that 3M doesn't make it anymore? I'm pretty sure they do. I do a have story...I know...not again...but anyway. Years ago i had an 8 inch sanding pad and not unlike the paper that you have, the paper that I had needed that glue...I was out and had to get the job done...Now, it's middle of summer in Canada and the bugs where horrid, I had a box of those fly strips in the shop so that I could control the insect problem to some degree...well, I took one of those fly strips, they are sticky on both sides, cut it up and stuck it to my sanding pad and the paper hung on as good as if I had glue and one application lasted for about 6 sheets of paper...the cool thing was that it was easier to clean than the glue, just peel the fly strip off and put on a new one.
Proof that necessity is the mother of invention...or in this case the distant uncle of improvisation.
Don't know if this helps you Brian, don't know if you can buy those fly strips anymore either.
Ray
Good story Ray,I too am old enough to remember that.We can still get the fly traps and we hang them in opposite corners of the booth starting in august to oct.Nothing worse than a fly divebombing into your last coat of clear or finding them dead in the middle of the hood after a bakecycle
Do you think maybe some 3m spraybomb interior glue might work?Obviously you wouldn't want to leave the sandpaper on it for days on end but I think it could work for short periods of time as long as you clean it off when your done for the day.
  #19 (permalink)
Old 08-02-2013, 10:20 AM
Thanks "Typical Car Guy", I have been told that I have a story for everything...probably because I've done some things in my life that makes me wonder how I made it this far...LOL.
Today must be Alberta day, so far we've a had a new member from Devon and 3 more posts, including yours from the best Province in the Country...Damn I miss Edmonton. I've only been to Lethbridge once and had a great time...that's another story from many years ago, my wife reads some of my posts and even though that was before I met here, I better just save that one...LOL.
Ray
  #20 (permalink)
Old 08-02-2013, 10:55 AM
carolinacustoms's Avatar
Automotive Extraordinaire
no??????????????
Go back and read his posts sir, he did try to find it with a search. When the search did not give the results he needed he came here for advice/answers. I have NO problem with that and I never said I did.
Kelly
  #21 (permalink)
Old 08-04-2013, 09:50 AM
deadbodyman's Avatar
Wiki Edits: 11
when that spray disc adheasive came out I remember thinking ,this stuff is the sheet..until then it came in a can and you squeezed it onto the pad it was basicly pine tree sap and it smelled like it too man that stuff was gooey...Every time we got a new guy they would eventually put to much on the pad and the paper slid off .I almost fired a guy for putting to much on and then letting the DA spin freely without being on the car...that paper slung off and stuck on the side of my face i was so peed off that goo was in my hair and everything..
that same old pine sap glue is used to stick the top on a glass slide when making slides for use with a microscope..
theres a repositioning spray glue they use at the arts and crafts store that'll work if you dont to want for the mail...
  #22 (permalink)
Old 08-04-2013, 12:33 PM
I mentioned this thread to an another gray haired old dude at work (the only other gray haired old dude there) and he told me he has a brand new ("NOS" LOL) tube of "Feathering disc adhesive" that he is going to bring for me tomorrow.
  #23 (permalink)
Old 08-04-2013, 02:30 PM
dinger's Avatar
We used to put a line of glue on the pad in a circle starting outside on the disk and working to the center. It didn't take much, the you would slap the disk on there, pull it up a few times until the glue was spread out a bit and tacky. Only the heavier 36 grits would fly off if you did it this way.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
  #24 (permalink)
Old 08-04-2013, 02:45 PM
Dan, it's so funny reminiscing about something so mundane. But it's so interesting how those memories start cooking in your head. The first time I saw that tube you posted of "Feathering disc adhesive" that was the first image that popped into my head, the squirting of the glue, then rubbing it around with the sanding disc and then peeling it off and slapping it down a few times. My God now many times did I do that? Was it simply thousands or was it tens of thousands? I don't know but it was a LOT.
Dan, another common practice was to "slap" the paper device made from a piece of 1/8" welding rod to knock the primer out of the paper so it would keep working. I have one out in my shop made from brazing rod that I have owned since my days at "The Early Ford V8 Shop" doing full on restos full time in 1978-79. It's worn almost half thru from the slapping on the paper! Can you imagine how many times you would have to slap sand paper to wear this rod thru? And we are talking 180 blocking primer, good memories I'll tell you that.
Glue Question Rear Deck Fabric beertracker Interior 2 11-02-2010 12:16 PM
Im sure this is a stupid question, but... hollywood2k Transmission - Rearend 8 11-10-2006 08:41 AM
Stupid question of the day Paint Codes rick458 Body - Exterior 1 03-24-2005 03:15 PM
stupid question kylejohn Engine 7 03-07-2005 10:15 AM
Glue and pleats question VonGooch Interior 4 12-30-2004 07:18 AM
