Stupid question regarding MII balljoints - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2007, 01:57 AM
Hie everyone
I am planing to build my own IFS based on MII components like spindles balljoints brakes etc, and manufacture the crossmember and upper and lower A-arms my self. Tubular chassie.
Now to the question:
Are the upper and lower balljoints pressed in place or screwed in place on the A-arm.
I have seen this type on summit racing:
http://store.summitracing.com/partde...5&autoview=sku
and this type on (screw in) on Day motor sports, at least I think it is for the MII suspension.
http://www.daymotorsports.com/product/342/c/S32/
I am confused , pressed or srewed, thats the question?
Thanks everyone
Best regards .........the dumb Swede
Old 04-03-2007, 07:44 AM
Most aftermarket arms have screw in ball joints...but if you are manufacturing your own...you can do it how you want. There is no right or wrong way.
Old 04-03-2007, 08:32 AM
Thanks
Which one is better then, screw in or ??
Is the taper on the ball joint bolt,the same shape on both ford MII spindles and GM spindles or ??
Best regards
Jimmy
Old 04-03-2007, 08:33 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Here is a selection of ball joints and housings Check this out as this may help you in your choice of ball joints and housings.
A taper reamer can solve the taper problem..Just do not take out too much material..
Sam
stupid 10 bolt question dustinh2988 Transmission - Rearend 3 01-25-2005 03:31 PM
Stupid Question Nightfire Hotrodding Basics 12 07-09-2004 05:53 PM
Stupid question about lifters ChevelleGuy Engine 2 08-29-2003 05:21 PM
This may sound like a REAL STUPID question Nos General Rodding Tech 18 06-11-2003 07:04 AM
ask a stupid question get ........ lookatme Engine 4 01-31-2003 04:21 PM
