stupid question--steering stabilizer same as a shock - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2006, 02:51 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Hi again,
I know this will sound stupid to everyone, but what is the difference between a steering stabilizer and a regular shock absorber?
I know they mount differently, but they look the same otherwise.
Can someone enlighten me, please?
Thanks
Old 03-06-2006, 04:24 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The main difference is that its valved differently. Street shocks are often times 60/40 with a soft damping for control and ride quality. Performance handling shocks are typically 60/40 to 70/30 with a tighter damping to control the stiffer spring rates often associated with handling suspensions. Drag shocks are usually 90/10 to promote weight transfer but are unsuitable for street use.
Steering dampers are always 50/50 and have damping that is matched to the steering system. Obviously a monster truck with 78" tires needs more damping than an 4x4 truck with 31" tires.
So that was the long answer. The short answer is: not much is different except damping rates, but you can't simply mount any shock to a steering stabilizer and expect it to work.
Old 03-06-2006, 07:52 AM
Brian_B's Avatar
Lost in the 50s!
Good enough answer....thank you.
Power Steering Set-Up Question jsrail Suspension - Brakes - Steering 3 10-16-2005 10:23 AM
Stupid Question Pitbullsandmustangs Introduce Yourself 2 10-12-2005 08:04 PM
steering box question - T-Bucket Gr8lite General Rodding Tech 3 08-29-2005 11:45 PM
Power Steering conversion question / Bump Steer robin58 Suspension - Brakes - Steering 4 08-12-2005 10:02 PM
Rear leaf spring shock question? gavinpierce Suspension - Brakes - Steering 2 08-10-2005 12:51 PM
