sub frame basics - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2006, 06:24 PM
sub frame basics
I just wanted to check some opinions on installing a 80 olds cutlass subframe on my 38 chevy sedan (new project). Has anyone out there used a cutlass subframe?? Thoughts??? Thanks
Justin
Naples, FL.
ID:	11120   Click image for larger version
ID:	11121   Click image for larger version
Old 03-23-2006, 07:36 PM
johnegoins
have done 37,38 chevy front steer cutlass is 2 long from crosmember to end of steering box will hit fender suggest rear steer or ms2 it will clear 1939 if u use 605 st. box good luck ''''
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
Critique My Frame STATUTORY GRAPE Suspension - Brakes - Steering 23 12-21-2005 08:51 PM
Cantilever system for air bags 53LEDSLED Suspension - Brakes - Steering 17 12-05-2004 03:26 PM
57 chevy frame alignment question... please help! Sanspants Suspension - Brakes - Steering 1 07-20-2004 10:15 AM
Body & Frame question ruiner808 General Rodding Tech 7 09-14-2003 05:54 AM
