Sub Frame Connectors 68 Firebird
HI , I am wondering what brand sub frame connectors will bolt on the easiest to a 1968 firebird I also have CalTracs, do I need to remove them to install the subframe connectors. Thank you so much.
Does anyone have any advice on this? Thanks
I believe mine are Competition Engineering. They worked well. I used the bolt in kind and then just welded them in. I would not recommend the weld in kind. Also remember the convertibles have an extra brace and you can not use sub frame connectors. There are ways around this, if you have a convert, let me know.
no convertable. I am still wondering about the caltracs because they also connect to the spring perch.Thank you very much
I just posted a question in a reply to "installing subframe connectors" could you please read it and see if you can help. Thank you
| 68 Firebird AC Question | SouthernRodder | General Rodding Tech | 3 | 05-31-2006 10:51 PM |
| 68 firebird tranny help.......... | maxpenguard1971 | Transmission - Rearend | 3 | 09-15-2004 07:26 PM |
| 68 Firebird engine/ trans mounting | psnieds | Engine | 4 | 08-16-2004 09:50 AM |
| wiring 68 firebird | ceiling-tiles | Introduce Yourself | 3 | 08-02-2004 06:23 AM |
| biggest tires for a 68 firebird? | ratfink14 | Transmission - Rearend | 4 | 11-17-2003 10:21 AM |
