Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sub framing a 57 pu
Old 03-12-2012, 11:38 AM
tony@roadstershop tony@roadstershop is offline
74 Vette ? I would go a different route than that.. like mentioned above, nothing special about that set up at all. Personally if you are wanting to keep and work off of the factory chassis, I prefer to atleast see an engineered crossmember used from a reputable manufacturer. I know there is alot of guys out there that have "successfully" clipped the front of these trucks with an early Camaro / Nova however I think it is an easier and better route and you can end up with better results.
