subframe ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2010, 07:57 AM
subframe ?
hello all
I,m grafting a camaro subframe onto a 40s chevy pickup . I woulddlike to have frame to ground measurements for a 71--79 z28 350 /350. suggestions welcomed !
Thanks larry
Old 06-27-2010, 01:55 PM
life is a temporary assignment
If its early 40's it will be to wide..If it's on say like a 48 or so..They work but still a little wide..The Nova is about 1.5'' narrower then the camaro.. I think that measurement is around 6''or 7''..
Old 06-27-2010, 06:01 PM
camaro subframe
Hello
I have narrowed it to match 40 width . I have it reasembled with control ams and such . I have read on past threads that the height is 8to 9 inches to the bottom of the sub frame tails. Is this correct ?
Thanks larry
Old 06-27-2010, 07:30 PM
Originally Posted by old trucke
Hello
Thanks larry
Keep in mine..If you narrowed a camaro clip..You might want to make sure your motor with headers still fit.. The 8'' to 9'' Might be to the top of the rear part of the clip..Set the clip where the back arms or level with the ground..(with the wheels on..)Then measure what you have..It will probably come down about 1.5 to 2'' with the weight on it...
This may help you..http://www.nastyz28.com/tech/framechk.html
Old 06-29-2010, 07:00 PM
subframe
New
went to nasty nates site the vertical dim. are not close to what I have . I,ve got 8 inches from floor to bottom tails of subframe, going by the two finger to bumber stop and the lower control arms being level ,I should be close. And yes the manifold or headers could be a opportunity .
Thanks larry
1955 Chevy Pickup and 1978 Camaro Subframe Maximus924 Suspension - Brakes - Steering 27 08-28-2012 06:23 PM
Camaro Front Subframe Swap ?'s Maro383 Suspension - Brakes - Steering 6 06-16-2009 07:43 PM
4 link subframe install ucmung Suspension - Brakes - Steering 5 04-10-2006 09:05 AM
34 pontiac 81 camaro subframe install ? mobythevan Suspension - Brakes - Steering 7 05-19-2005 12:17 PM
subframe installed too high help sawzall Suspension - Brakes - Steering 24 07-25-2003 10:22 AM
