subframe - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2004, 08:28 PM
PaulNJ53Ford's Avatar
subframe
hi will a subframe from a camaro fit on 1953 for customline? I want to put air ride and disc brakes and want to try t o install ford 5.0 engine thanks for any help
Old 10-07-2004, 07:21 AM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
Will it fit all depends on the year of the Camaro. You should break out the tape measure and check track width, frame widths etc. Also determine how the sheet metal will remount. There are some good discussions regarding subframing at the beginning of this section you might want to check out.
The Following User Says Thank You to advanced design For This Useful Post:
pveteran (12-20-2014)
