subframe connectors - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2003, 12:56 AM
New Member
Post subframe connectors
i want to install subrame connectors in my 70 camaro and was woundering what work would be involed in that sort of thing.
Old 02-16-2003, 08:46 AM
BOBCRMAN@aol.com's Avatar
Post
are you going to fabricate? or use a kit. the kits require loosening the rear of the subframe mount, and removing the rear spring front mount. so you can slide the bar over or into the sub and under the spring mount, the most frustrating part is the body nuts always break off and you have to replace them with new.
Old 02-16-2003, 01:20 PM
New Member
Post
i was thinking of buying the bolt on ones.
