Subframe Conversion Pt.1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2012, 08:51 AM
After countless hours of rigid driving and wincing at every bump, the time to change the front suspension has came. The following photos are the very beginning of what is going to be a fun and gratifying learning experience. So far we have stripped the subframe of all unneccessary brackets, hardware, and of course the old lines. We have taken off the old A arms and replaced them with some beefier tubulars. New rotors are being installed and the front sheet metal of the old pickup is being stripped. And to dress it up a little bit, a slightly shinier grill will be installed!!
ID:	66098   Click image for larger version
ID:	66099   Click image for larger version
ID:	66100   Click image for larger version
ID:	66101   Click image for larger version
Old 06-16-2012, 09:02 AM
i decided to post some pictures showing the current ride height with the straight axel and a mock up of the new grille the tired old 350 is being pulled and replaced with the 5.7L in the last post.
ID:	66103   Click image for larger version
ID:	66104   Click image for larger version
ID:	66105   Click image for larger version
ID:	66106   Click image for larger version
subframe ? old trucke Suspension - Brakes - Steering 4 06-29-2010 08:00 PM
Subframe??? 46fmaster Hotrodding Basics 12 02-10-2007 01:21 AM
Camaro subframe bigbada1 Hotrodding Basics 8 11-16-2006 07:28 PM
Subframe DIXIEPAUL Suspension - Brakes - Steering 3 01-11-2006 01:25 PM
subframe PaulNJ53Ford Suspension - Brakes - Steering 1 10-07-2004 08:21 AM
