Subframe Conversion Pt.2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2012, 06:51 PM
Ok so since the last post, my truck has been cut in half...haha but we have the subframe now tacked into place. More pictures to be taken tomorrow when hopefully the subframe will be finish welded into its new home.
ID:	66261   Click image for larger version
ID:	66262   Click image for larger version
ID:	66263   Click image for larger version
ID:	66264   Click image for larger version
Old 06-23-2012, 06:53 AM
deadbodyman's Avatar
Wiki Edits: 11
looks like fun, keep us posted...
Old 06-23-2012, 09:48 AM
Be sure you hang your sheetmetal on there to be sure you have it placed with the right wheelbase before you weld it in solid! And you need to be sure you put the upper control arm shafts at the right angle. If you tilt the sub frame forward or back you are going to throw that all off. A little is fine, that is what shims are for but I have seen where they are all screwed up and offset upper control arms shafts have to be used to get it aligned. Using a protractor get the correct angle off a stock Camaro.
Old 06-29-2012, 10:59 PM
Will do!! thanks for the advice! we have been painfully exact on measurements and think we have it right where we need it! im posting more pictures tomorrow i believe... i didnt realize i could make an actual journal until after i started haha
Old 06-30-2012, 03:45 AM
poncho62's Avatar
Wiki Edits: 5
Are you making a butt joint or laying the rails under yours?
I laid the rails under on mine, makes a stronger joint, I feel
Ontario Rodders
Old 06-30-2012, 08:03 PM
yep layed them under..in a way! haha im posting the final product on Todays installment of my journalish thread series
Subframe Conversion Pt.1 Nifty50Chevy Hotrodders' Lounge 1 06-16-2012 08:02 AM
subframe ? old trucke Suspension - Brakes - Steering 4 06-29-2010 07:00 PM
Subframe??? 46fmaster Hotrodding Basics 12 02-10-2007 12:21 AM
Subframe DIXIEPAUL Suspension - Brakes - Steering 3 01-11-2006 12:25 PM
subframe PaulNJ53Ford Suspension - Brakes - Steering 1 10-07-2004 07:21 AM
