Subframe Mounts for a Second Gen Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2004, 09:52 PM
redcamaro4spd's Avatar
drive it like you hate it
does anyone know what the best choice for subframe bushing/mounts is? I want something that I do not need to change for a while, so I do not really want to look at rubber unless it is a lot cheaper. I know solid aluminum bushings are sold in summit for 40$ and I was wondering if any companies sell polyeurethane or polygraphite bushings. I fear the aluminums may hurt ride too much.
Also, what is the easiest way to put these in? I will have the drive train removed from the car within the next month so I plan to do it then. I was thinking, remove the bolts on one side at a time and lift that side of the body off the subframe and reinstall the new ones. is there an easier way?
Thanks in advance guys,
Ben
Old 06-30-2004, 10:57 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
JEGS and Summit carry Energy Suspension parts, JEGS' price is around $40.
http://www.jegs.com/cgi-bin/ncommerc...75&prmenbr=361
Also, Prothane has a list of dealers on their site.
http://www.prothane.com/
Many of the resto places probably have them as well.
Old 06-30-2004, 11:04 PM
77z's Avatar
77z 77z is offline
Go big or go home
i have always figured it was best to remove the whole frame to change the mounts. i dont like having to twist / force the frame to move any deflection in the mounting points will adversely effect the drive on the car. i think its best to just support the tub carefully and remove the rad saddle bolts and frame bolts, you can also paint / por the frame while your at it
Mike
77 Z28 496 9 inch
10.23 @ 129
