Subframes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2010, 07:58 AM
Subframes
I was wondering if a 1980's sub frame for a camaro would fit in a 1971 camaro
Old 05-01-2010, 08:13 AM
big gear head's Avatar
High Performance Rear Ends
Camaro, no e. The '74 to '81 Camaro used a slightly different sub frame because of the bumper mounts. '74 was the first year for the big bumpers with the shock absorbers. Other than that they are about the same. After '81 the Camaro frame was completely different.
Old 05-01-2010, 08:50 AM
ok thank you
Old 05-01-2010, 03:50 PM
After 1981, the Camaro didn't HAVE a subframe. The front suspension was McPherson struts that bolted directly to the unibody shell.
Old 05-11-2010, 06:39 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
There is another difference between early and later F-body subframes. The distance between the body mounting points on the 70 1/2 to 74 subframes is shorter than the 75-81 subframes. The difference is several inches but I do not know the exact amount.
Astro Van Front End 523100 Suspension - Brakes - Steering 17 12-11-2010 03:45 PM
subframes panel427 Introduce Yourself 1 09-22-2007 02:52 PM
SubFrames automan62 Suspension - Brakes - Steering 5 02-07-2006 04:57 PM
'53 Chevy Bel Air 4dr......Subframes??? JMiles Suspension - Brakes - Steering 4 07-13-2004 12:43 PM
Scotts Subframes Juans55Olds Suspension - Brakes - Steering 0 11-07-2003 02:51 PM
