subs in cab - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-10-2009, 07:43 AM
302 Z28's Avatar
That is correct, subs require a certain amount of cubic feet of enclosure to operate properly based on the size of the sub. People who do not understand this mount subs just like a regular speaker then wonder why it doesn't sound right.
Vince
  #17 (permalink)
Old 03-10-2009, 07:54 AM
72fordlb's Avatar
BARN BURNING BIG BLOCK!
ill find away i mite take the gas tank out and put it under the bed then i will have room behind the seat.
  #18 (permalink)
83SILVRADO's Avatar
GROUND POUNDER
Just slap em behind your seat. if you really are going to do this, you may need some shallow mount subs that can fit behind the seat in your cab. You are also going to need a box that has the correct amount of square footage to have the subs working appropriatley. an amp, depending on the size of the subs and how many, it will vary. for 2 1000 wats is plenty. You also gonna need a new head unit, if you have the stock one... beleive me there is a lot of problems with figuring which wire hooks up to where when you are hooking modern stuff to older stuff. ive done it. just buy a new head unit and this can all be avoided. good luck
  #19 (permalink)
Old 03-10-2009, 08:08 AM
72fordlb's Avatar
i need to relocate my gas tank first then i will drop in 1 12inch sony xplod sub with one 1000 watt amp
  #20 (permalink)
Old 03-10-2009, 08:10 AM
83SILVRADO's Avatar
GROUND POUNDER
you dont have modern head unit? that may create some problems...
  #21 (permalink)
Old 03-10-2009, 02:49 PM
72fordlb's Avatar
dude i have a new radio and a amp all i need is the sub
  #22 (permalink)
Old 03-10-2009, 05:35 PM
302 Z28's Avatar
Thanks for keeping it civil guys.
Vince
  #23 (permalink)
Old 03-10-2009, 07:05 PM
72fordlb's Avatar
ahhh n problemo we r buds we arnt fighting.
  #24 (permalink)
Old 03-10-2009, 09:23 PM
Actually there are subs designed to work without an enclosure, they have what is called an infinite baffle design. They are rare, but they do exist. (I'm an x car audio guru). That being said, a sub in an enclosure will always sound better....
And in a cab that small, a 12" running 1000 watts is OVERKILL!!! unless its only purpose is to piss off the neighbors, or impress the buddies standing 100 feet away. A properly tuned 10" (or even an 8" for that matter) will give you loads of bass inside the cab, and you might not go deaf. But I know what being young is about... I had 2 12" running 1500 watts a piece, in the cab of a 86 chevy at one time (SPL competition truck). They were mounted in bandpass boxes in the box of the truck, then ported into the cab... This may be a good option for you, and is one of the only ways to get a big enough enclosure in a regular cab truck. But it does mean knocking a hole in the box and back of the cab, then using the same rubber they use for sleepers to attach the two together.
  #25 (permalink)
Old 03-11-2009, 12:59 AM
DaSouthWon's Avatar
I put up the tools against$300
If space is really a commodity in your truck and your looking for something that sounds good and your not trying to piss off the folks in the car next to you, you may not even need a sub. Sealing a door with dynamat or some other sort of deadener does a great job of reducing resonance and improving thump. I've got a set of Image Dynamic Chameleons which have a 6.5" "midbass" driver in the doors of a 70 Charger. I put 150 watts to them with an Xtant amp and I would bet money that they can hit 55-60 Hz +/- 3dB up to 90dB or so. The important part is making sure that you've got a good seal between the front and back of the speaker. Soundwaves coming out of the back of the speaker will cancel out the soundwaves coming out of the front if they arent well seperated. You can also google free-air subs for a sub that does not require a box to function properly. They work well stuck in the package trays of cars and are designed to put out volume not sound quality.
  #26 (permalink)
Old 03-11-2009, 06:44 AM
DanTwoLakes's Avatar
Wiki Edits: 22
What's the point of having a stereo (sorry, sound system) in the first place if you can't piss off the neighbors or impress your buddies..........?!
OFChevy is right, you could do some serious damage to your hearing in a space that small. Remember, an increase of 3db is doubling the loudness of the sound, and an increase of 10db means the sound is 10 times as loud. In other words, 50 db is 10 times louder than 40db. Take care of your ears!
  #27 (permalink)
Old 03-11-2009, 08:16 AM
My car came with two 10 inch subs. I took them out. It vibrated the car from front to back. Just too much for me. I like good tight bass. What i call punchy bass or more of a musical bass. Most people that do go with two or three 8inch subs. I installed two 8inch subs and it sounds killer. Much better then 10s IMHO. My son installed two 8s in his car and he really likes-em. I had a few systems. One had one 12inch and it sounded good, just not as good as a couple of 8s. The best part about 8s is. You only need a very small box. Box for my 8s is 22X11x6. That's what was recommended by JL Audio. I have one 500 watt amp powering both. Its 250 watts a side. Your ears and taste may very.....
  #28 (permalink)
Old 03-11-2009, 08:22 AM
83SILVRADO's Avatar
GROUND POUNDER
i have installed about 10 systems. i really like doin it, but i would never consider puttin any in my truck. its just not somethin i would ever consider spending money on. probably wouldnt be able to hear em anyway! my truck has a reputation for bein extremely loud
  #29 (permalink)
Old 03-11-2009, 09:16 AM
DaSouthWon's Avatar
An 8" diameter sub is going to put out much tighter bass than a 12" sub thats being fed the same amount of power simply due to the mass and weight of the cone being moved. Additionally a sub in a small sealed box is going to have much better sound quality and accuracy than a sub in a large ported box.
  #30 (permalink)
Old 03-12-2009, 11:10 PM
Bingo DaSouth....
It comes down to do you want loud, or quality, rarely do they meet unless you have really deep pockets....... and hearing protection!! Anything over a 10" that is under $800 is just for loud and nothing more.....
Cab top repair nightmare luvinmy65 Body - Exterior 13 01-26-2009 08:46 AM
Cab dolly for 47-54 chevy truck sevt_chevelle Body - Exterior 2 06-19-2006 08:27 AM
86 s-10 vibration cab mounts bad? catscan4free Body - Exterior 4 01-26-2004 03:23 AM
cab corners pauldenis Body - Exterior 2 11-07-2003 11:33 PM
