Suburban - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2008, 10:08 PM
jrm123180's Avatar
A Learning Hobbist
Suburban
I guess this questions could fit in a few different forums, but could anyone tell me if I took the plow off the 1979 Chevy 1/2ton pick up, would it mount on a 1993 Suburban?
Thanks,
Steve
Old 08-03-2008, 03:55 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Wrong post,
Sorry
Old 08-03-2008, 04:18 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
You most likely have to do some Modifications the 79 has a different frame than the 93.
Fabrication will be the word I will use.
is the 93 the ones with the torsion bar suspension?
Snow Plow Brrrrrrr! & its 98*F in the shade here .
R
"SlowRide66"
"Illegitimis non carborundum"
Old 08-04-2008, 11:32 AM
Thanks,
Steve
Completely different frames. The 79 is a solid front axle and leaf springs (assuming it's a 4x4), the 93 has an independent front axle with torsion bars. The frame width is different.
« bad frame | Wheels »
2003 Suburban Performance Upgrade Options? Houston54 General Rodding Tech 1 11-26-2007 08:14 PM
87 Suburban fuel pump help needed Mustangsaly Engine 14 10-29-2007 10:04 AM
1995 suburban 1500 series 4by jtyler Suspension - Brakes - Steering 1 08-07-2007 08:42 PM
87 Suburban tbi to carb swap, question on tranny Mustangsaly Transmission - Rearend 3 05-26-2006 08:10 PM
fast suburban? firestone Engine 2 05-16-2005 09:33 AM
