suburban transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2009, 10:53 AM
i killed the motor in motor in my 91 caprice im considering buying a 1994 suburban 2 wheel drive it has a bad trans will my 1991 700r4 bolt and funcyion correctly thank you
Old 07-19-2009, 10:57 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no.
the 1994 Suburban has a 4L60E trans..computer control shifted and pressures.
the 1991 trans is non electronic control - shifted
Old 07-19-2009, 11:23 AM
ok
so can i bolt it up will it shift by control of pressure or will it send codes that the trans is not plugged in and mess with everything
Old 07-19-2009, 11:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The computer system looks for feed back from the 4L60E trans. No electronic trans and trouble codes are set
THe 1991 will bolt in and you need to hook up the TV cable
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
How to remove transmission from 1953 Suburban Sly's 53 Suburban Transmission - Rearend 7 03-07-2005 05:11 PM
1993 Suburban Transmission Swap dlac1769 Electrical 1 10-30-2004 02:09 PM
1993 Suburban k1500 Transmission upgrade dlac1769 Transmission - Rearend 3 10-23-2004 07:26 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
