Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Successful painting in cold weather....
Old 12-01-2009, 11:08 PM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by kenseth17
Looks good centerline, but I think you are confusing epoxy and etching primer again. Etching primer isn't 2 part, okay it has 2 parts, a vinyl? resin/ zinc, and acid, but its not really a 2k product, and you really don't want to paint over it without using another primer first-most tech sheets I've seen give strict warnings against painting directly over them. Maybe you could paint over them or some manufactures say its okay after allowing plenty of time for the acid to leave, but most say its a no no. Etch primer usually has very little build and if you apply them heavy at all will be running all over the place.
Epoxy on the other hand is 2k . It doesn't contain an acid to etch the surface, its more like a glue, so surface should be sanded for adhesion, but much better then an etch primer and less chance of leading to any problems with other products or down the road.
OK, the technical term is etching filler (I changed my original post to reflect that fact). Its Martin Senour Chromate Free Etching Filler Part # 15211 with 15212 hardener. It's a two part etching filler that Martin Senour recommends for bare metal, fiberglass, galvanized steel, cured body filler, aluminum, OEM enamels, and OEM lacquers. I like everything about it except the ugly green color.
