Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Successful painting in cold weather....
Old 12-02-2009, 08:40 AM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by Frisco
.......How are you keeping the dust down?
Without a booth its always hard to keep dust down.... even in a booth you can get little dust nibs. What I do is blow the immediate area off and let the whole area sit for at least 20 minutes. Then I wipe down the piece with wax and grease remover before I shoot the paint. The trick is to move slowly around the area while you're doing anything so you don' t kick up any dust that might remain. Of course spraying will kick up some but that's why I try to spray as far above the floor as possible. If you notice the gas tank was mounted on a home made mini rotisserie above my welding table a good 4+ feet off the floor and the front edge of the table was covered with masking paper. That way, based on the direction I would be spraying any dust that was kicked up by spraying would (hopefully) move away from the piece.
