Successful painting in cold weather....
Or at least what works for me.
When it comes to painting in cold weather unless you have a heated shop painting large objects like an entire body is probably not a good idea. However, you can paint moderate sized panels if you take some precautions first. To begin with the temperature of the panel needs to be as warm as possible (within reason of course). I use heat lamps placed about 3 feet away (on both sides of the panel) and leave them on long enough to warm the metal to at least 75 degrees. You can see how I used these on my gas tank below. http://hotrodsandhemis.com/DeuceGasTank/img_1892a.JPG Because modern paints need a temperature of at least 55-60 degrees in order for proper cross linking to take place it is important to not only preheat the metal but continue to use the heat lamps during and after painting. I leave them on for at least 4 hours after the last coat but 6 hours wouldn't hurt. Here's the finished product. One deuce gas tank painted 1964 Ford "Candy Apple Red". Its not really a candy but that's the name Ford gave it. In this case I used Martin Senour's Crossfire single stage urethane over a two part etching filler. Two mist (tack) coats followed by a medium wet coat and then a wet coat with 15 minutes between all coats. Outside temp 30 degrees, shop temp 50 degrees, metal temp at least 75-80 degrees. http://hotrodsandhemis.com/DeuceGasTank/img_1897a.JPG The results were outstanding when you consider it was not painted in a booth and the conditions weren't optimum. I've used this technique in even colder weather and it seems to work just fine. Painted the cab on my pickup using heat lamps and PPG Omni single stage about 5 years ago and it still looks perfect. |
Lookin totally narly :D :thumbup:
Vince |
Looks good centerline, but I think you are confusing epoxy and etching primer again. Etching primer isn't 2 part, okay it has 2 parts, a vinyl? resin/ zinc, and acid, but its not really a 2k product, and you really don't want to paint over it without using another primer first-most tech sheets I've seen give strict warnings against painting directly over them. Maybe you could paint over them or some manufactures say its okay after allowing plenty of time for the acid to leave, but most say its a no no. Etch primer usually has very little build and if you apply them heavy at all will be running all over the place.
Epoxy on the other hand is 2k . It doesn't contain an acid to etch the surface, its more like a glue, so surface should be sanded for adhesion, but much better then an etch primer and less chance of leading to any problems with other products or down the road. |
I've used it. I'm curious, So how, or what in it makes it etch? Is there an acid in it?
Look's very good.. ;)
Vince |
Good suggestions for folks like me that are trying to learn painting techniques. How are you keeping the dust down? |
Another trick I used when spraying small parts in my garage is to first dust the floor with a little clear to seal the dust to the floor. Yes it waste a little clear, but I figure it's a wash as now I don't have to sand some clear off to get rid of dust nibs.
Vince |
And weird, the PDS says can be directly topcoat, not often you see that. I am guessing the 15212 is really an acid/reducer, not an activator? |
Vince |
| All times are GMT -6. The time now is 09:59 AM. |
