sucessful cam break in- what oil to use ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2005, 05:54 PM
fast68's Avatar
likes chevy trucks & boobies
those of you who have sucessfully brokin in cams- what oil did you use
from searching i have read that straight 30 weight is the stuff to use- and EOS for sure
what brand/type of oil is known to be safe for this ?
need to break in cam on old higher miles 350 with summit cam, soon
the original cam died three galled lifters, maybe 4, worn into feet of them, #6 exhaust seems to have been the worst(occasional popping out exhaust)
the engine ran good and strong, i have no idea why it ate the cam, engine still was running original nylon tooth cam sprocket and timing set(1974 CMJ stamping 350)
i have no way to disassemble and clean engine, or even pull pan, all i can do is oil and filter and hope
thanks for anything
Old 10-30-2005, 06:07 PM
ragenrat638's Avatar
CRASH TEST DUMMY !!!!!!
really any quality brand oil should do....the key is
#1 use the cam lifter break-in lube supplyed with lifters and cam....or buy some ...
#2 run engine at 2000 rpm for 20 min....upon first start up....
i like having a buddy there....to help look for leaks....fill the radiator...
i like caster oil....my self.....
hope this helps....your pal mark
Old 10-30-2005, 06:09 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Do what the cam manufacturer recommends. If they say use soft springs... do it.. it is easier than changing the cam and lifters a second time.
Old 10-30-2005, 06:12 PM
powerrodsmike's Avatar
Wiki Edits: 161
Is this a new cam that you just put in? Did you put molylube on the cam and bearings when you assembled it? 30 wt should be fine to break it in with if you pre lubed it when you assembled it. Fire up the motor, don't let it run below 1500 rpm for the first 20 minutes or so. Vary the rpm's from 1500 to 2500 during that time. That will get a good start on breaking that cam in right. Change your oil and filter after 50 miles.
BE different....ACT normal.
Old 11-21-2005, 11:19 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
I installed a Comp Cams Extreme energy cam in my Hemi and used their package of lube that came with the cam. I haven't started the motor for the first time yet, but I have noticed that quite a lot of the cam lube didn't seem to "stick" to the lobes, and they appear to be almost dry. I'm sure that there is a thin film of lube left, but I'm going to re-lube everything once more before start-up, probably with Red Line assembly lube. I am not too impressed with the stuff that was supplied by Comp Cams.
In all fairness, its been a while since I installed the cam, and I suppose the lube would have worked fine if I started up the motor as soon as I installed the cam. But long term, the lube couldn't hang on.
I'll also dip the lifters in Engine Oil Supplement (now called engine assembly lube by GM) as a precaution, and I 'll do that just prior to start-up.
Steve
Old 11-21-2005, 11:55 AM
johnsongrass1's Avatar
Race it, Don't rice it!
MOly paste won't fall off overtime. I've got a cam with moly paste on it in a 358 short block been sitting for over 500 days without falling off or dripping. Red line assembly works really well.
Old 11-21-2005, 12:11 PM
techinspector1's Avatar
Wiki Edits: 326
Steve
I've experienced the same thing in the past. I've corrected it since by scrubbing the cam with solvent and a hard-bristle nylon brush to remove any anti-rust lube that may have been applied by the cam grinder and then washing it to within an inch of its life with Ivory Liquid and hot water. I blow it dry and work the moly into the pores of the metal with my fingers, using all the moly supplied. I use GM EOS in the oil (30 wt. detergent), prime the oil galleys, prime the carb and set the timing close so that I don't have to grind the motor on start-up. Closely monitoring a known-good oil pressure and water temp gauge, I bring the revs to minimum 2,500 for minimum 20 minutes. Shut down, drop oil and filter, new filter and fresh oil and another can of EOS for 50 miles. Drop oil and filter, re-load with new filter and 10-W-30. Forgot to mention, single OEM springs on startup, changing them to matching springs after 50 miles. Good to go.
Old 11-21-2005, 12:16 PM
That's how I do it and I've never had a problem. Make sure everything is ready before you start it and don't shut it off for at least 15 min.
Old 11-21-2005, 11:28 PM
I used Valvoline 10W-30 racing oil as it is high in zinc. Added an extra qt. of oil to help the splash lube. Also used a bottle of GM EOS.
Got the racing oil at NAPA. Special order and more expensive than conventional oil.
Synthetic oil?? Mightymouse Engine 40 02-23-2012 05:05 PM
Engine break in oil 63Fair Hotrodding Basics 11 12-03-2011 10:51 PM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 02:51 PM
cam break in jo5hi3 Engine 2 03-19-2004 07:34 PM
hydrolic lifter cam vs. solid lifter cam chevyelc81 Engine 12 09-09-2003 08:38 PM
