Sudden engine stumble - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2008, 06:03 PM
My 82 Elky with V-6 , 292 with 2bbl manual carb,manual vacumn advance HEI distributor, auto trans was running fine, I made a stop and shut it off, restarted and drove down the street, made a u-turn and on normal acceleration the engine started to stumble badly and now backfires thru the carb. if you rev the engine. I checked the timing, it is right on, but I did notice the timing light flash seemed to miss a beat every so often. Cleaned the carb, adjusted the choke, no better. Any suggestions please? Thanks, Crash
Old 06-16-2008, 12:40 PM
I would look into the distributor - would be my first guess unless you have a air/fuel ratio meter hooked up on your ride. Maybe the vacuum advance is not right? You said that it's firing when an intake valve is open. But - if your motor is running REALLY lean then it would act like that, too.
I've had problems like that before that absolutely drove me crazy - so I installed a air/fuel ratio meter on my headers so I can tell if it's fuel related or not or at least put my troubleshooting better in the ballpark.
Old 06-16-2008, 02:21 PM
SSedan64's Avatar
That U-turn may have dislodged some water in the bottom of the tank.
Old 06-16-2008, 04:27 PM
Sudden Engine stumble
I have a feeling its in the coil, or distributor, due to the occasional skip of the timing light.
Old 06-16-2008, 07:27 PM
Let us know when you fix it, ok? Good luck.
Old 06-16-2008, 07:32 PM
No luck so far. Thanks
Old 06-16-2008, 08:25 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Check your fuel supply hose from the tank to the fuel pump for cracks. If it is running too lean from the fuel pump sucking some air, it will miss fire. If that hose is now split enough to suck air, check your engine and transmission mounts for ripping.
Since you made a stop for a little while, then restarted, I would do a compression test, to determine whether it has a stuck valve, or not.
Either one of these are viable problems for your drive ability description.
Stephen
Old 06-16-2008, 08:56 PM
Thanks I'll check both things, Crash
Old 06-16-2008, 09:24 PM
Stephen
What about removing both valve covers and using a remote starter/hand cranking the motor to check for a stuck valve?
But - a compression check would be good, too - it lets you know where you stand.
Old 06-16-2008, 09:41 PM
My 2 cents worth
Wiki Edits: 3
You could check for one by hand cranking, but if it is sticking, and not stuck you won't find it. The compression test should be done with the engine hot.
Let me also note: Bad gas will cause this every time. Right now I am battling with a dyno shop (to be named later) over a possible case of "bad gas" right now. (my Avatar)
Old 06-17-2008, 01:00 PM
Engine stumble
It may be a coincedence but my Sunoco station has just switched to a 10% Ethenol mix ? I'm wondering if this is the problem or if in the switch water may have gotten in their tanks?
As soon as it stops raining I will have a lot of things to check to straighten this out.
Just in case I have put a bottle of dry gas in the fuel tank.
Old 06-17-2008, 02:29 PM
Years ago - for what it's worth - I was having similar problems like that. I kept chasing bad gas and the like. I even went so far as to re-plumb the fuel line so that I could have the fuel pump pull fuel from a 5 gallon fuel tank that had known good fuel. It turned out the ignition wiring in my '69 Merc needed to be replaced. . .
Old 06-17-2008, 03:20 PM
Sudden stumble
Thanks, Yeah, I'll have my hands full with this one.
Old 06-17-2008, 04:14 PM
My 2 cents worth
Wiki Edits: 3
You bet you will. With that new reformulated fuel your are running now, you will need to check all of your tune-up related parts, and adjustments.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
What would cause engine to stumble and die? trapperjack Engine 4 11-02-2006 07:53 PM
